Should i use this fretboard blank?
Windir
I have had a slotted rosewood fingerboard blank at my place for 1,5 years now, and i live in place where climate is quite harsh at this time of the year. As a result, the blank has warped a bit. Should i still use it, or is proper intonation forever out of reach?
Bill Hicklin
How much is "a bit"? If no more than a few mm of bow, it can be flattened with ordinary clamping pressure, no problem: the neck will hold it jst fine.
emoney
Can't imagine the intonation is an issue, as the slots didn't move I wouldn't think. Like Bill
asked, "how much is a "bit" in your estimation". Most fretboards because of their thinness
won't cause a major issue once glued in place. Pics would help.
Fret Hopper
If you are concerned about the neck twisting once the fret board is glued down, use some carbon fiber bars to reinforce the neck
From the ozone...
Mark
^ or use a thick neck profile. Does the same thing with nothing 'artificial' in the neck.
Bill Hicklin
In any neck with a steel or c/f truss rod, not an issue.
