Should I be worried about this?
AndrewLP1081996
I noticed the long scratch on the back of my guitar today. As I looked closer I noticed it is pretty deep. Does it look like a crack to you guys? If it is what can I do to fix it?
Thanks Andrew
mux164
i wouldnt worry if it was on my guitar, if it opens up run some glue into it, i am guessing thats what others would say
AndrewLP1081996
Ok thanks mux I will probably glue it after I finish sanding. All depends on how much it opens up I guess
H.E.L.Shane
that's not at a glue line then??
don't wait until you've finished sanding...
wick that bastid full of water thin CA right now and then level it off as you sand
emoney
You'll be able to tell a lot better than we can with a picture. Run you finger down it and you can feel if it's a crack or not. I'm with Shane in that the first thing I thought was that it's a joint, glue line. Definitely take his advice and fill it now so that you can sand away any evidence before you get too far along, assuming it's a crack.
AndrewLP1081996
Ok guys thanks. It is a one piece body so I'm guessing its a crack. I will fill it with super glue and sawdust when I get home from school. I could feel the crack barely but I will glue it to be safe.
