They are similar. Antiquities are a bit 'softer' in how they ring out. A tad more mellow, for lack of a better term.
Seth's are more immediate and a slightly quicker attack on the note.
I have them both. Antiquities in an LP, and Seths in an ES-335. Both are great, and they are fairly close.
I put the Seths in ES335 because those guitars already have a thick midrange due to being hollow, so it fills out.
I will add that I play more bluesy rock. Amps often on the edge of breakup. I don't play high gain. So folks that play with amps like that, or metal, might find antiquities a bit squishy.
the antiquities use weakened magnets. they all use a2 magnets,
Thanks for all the input gang. So I'll open the door for more conjecture - will the Seth Lovers be too bright to install in my R7?
Only you can decide what is too bright for your guitar. Personally, I would rather have a bright guitar than the other way around. If it's too much, that's what the Tone knobs are for!Thanks for all the input gang. So I'll open the door for more conjecture - will the Seth Lovers be too bright to install in my R7?
So, strat Pickups it is!No humbucking pickup should EVER remind anyone of James Taylor.![]()
