Cygnus X1
- Joined
- Jul 18, 2009
- Messages
- 6,570
- Reaction score
- 2,968
Hmmm.
This one has me scratching.
A Cygnus 7 with the usual Gain 1 and Gain 2 setup.
Symptom is the signal is weak and distorted.
First looked for anything obvious like loose connections, bad grounds, bad tubes, and voltages.
Nothing stood out as too unusual.
So I set up a reference 1K signal on one channel of the scope, and put the probe for the other channel at the speaker and started working backwards.
I was getting the same distorted wave all the way back to the tone stack.
So I placed the probe at the master volume and changed where the signal was being injected by the signal generator (1K sine).
Distorted through the first gain stage, then it would clean up as soon as I got to the second gain stage.
So pin 7 input is funky, but pin 2 is relatively good.
Here's a pic to show it.
Bottom signal is the clean reference, top is gain stage 1, then 2 respectively.
Now to hunt it down.
I'm going to put the probe closer to the stage 1 functions and probe around there.
Don't know what I will find but it shows what a great tool a scope can be for troubleshooting what our ears can't discern.
Don, don't worry, your Tek scope is still here.
Just that Channel 1 is flaky.
I just need to get into it and clean it up and repair that fine tuner on the voltage divider.
I wanted full use of both channels for this experiment.
This Hitachi was dirt cheap ($22 local surplus), 20Mhz, and has a nice clean signal.
The display is skewed at an angle though...something I'm sure there is adjustment for somewhere.
Also got a spare scope probe for $3.00 (!!!) at a thrift store.
Brand new in the package.
I was shocked to see it and they certainly had no clue what it was for!
