Schaller GTM Bridge
velvetsunrise
Hi looking to replace the standard Gibson Nashville bridge on my 01 LPS, with the Schaller GTM 45060
My main concern is the string spacing, schallers website has 10.5mm string to string, so 52.5mm E-E, i have measured my bridge and my string spacing seems to be a tiny bit less than this.
Anyone tried the schaller? do the schaller supplied posts fit Gibson bushes?
Or should i just get an ABR-1 and reem to fit the Gibson Nashville posts?:hmm:
SABLE
if you like the schallers, get them. if they dont fit, you can just refit the screws easily.
SumKnowledge
Hi, you are referring to F-spacing aprox 49mm E-e is standard Gibson spacing and aprox 52mm E-e is F-spacing (Fender or Floyd Rose Spacing). You need to be aware that the pole pieces of your pickup will not align correctly if you have an F-spaced bridge and a standard spaced pickup (or visa versa). best stick with normal spaced bridge if you dont want to cange your pickup.
Cheers Chris:jam:
