Saddle replacement on a Nashville bridge
The_Sentry
This is a stupid question..but here it is...
How do you get the screws out of the Nashville bridge? I have a TonePros II on an Epiphone that I want to slap some graphtech saddles into.
thanks in advance...
The_Sentry
Man, after searching all over the place, I end up back here. This is all that I could find, hope it helps. http://www.mylespaul.com/forums/custom-shop/7478-tuneomatic-low-e-string-saddle-screw-broke.html
Stop the presses! Here's Tonepros' PDF http://www.tonepros.com/images/Removing%20or%20changing%20a%20TonePros%20saddle.pdf
Ah, I thank ye kindly but that's an ABR-1 bridge. 'tis all good though....I think once I get around to it again, I may just end up replacing my tonepros with a graphtech. (Not any time soon though...)
Jason
I believe mine had some little clips holding the saddles in, need to squeeze those until they pop out.
Csharp
"......that's an ABR-1 bridge." Are they really THAT different. I would think that the Nashville comes apart the same way. On some, the wire is purely cosmetic and they still have clips holding the screws.
The_Sentry
They're somewhat similar. The Nashvilles don't have that retaining wire, but instead have a nut on the other side that....doesn't come out. (And the chances of stripping the adjustment phillips head is pretty high...)
The ABR-1's don't supposedly have the tone, but they're much easier to pull apart...
