ReWind Prewired Les Paul 1959 Wiring Harness w/ NOS 50s Sprague .022 PIO Bees Long Shaft & Short Shaft
Veritas0Aequitas
Up for sale is a ReWind Prewired Les Paul 1959 Wiring Harness w/ NOS 50s Sprague .022 PIO Bees Long Shaft & Short Shaft
I have one Long Shaft Harness and one Short Shaft Harness.
$290 shipped each. $570 for both. I'll throw in a 1/4" 3-Way jack if you buy both.
This was purchased on a custom order from ReWind a few months ago and never used. I never used it for a project and decided to sell it. Here are the details:
  • CTS 500k Pots
  • Custom Vintage Replica Taper
  • +/- 7% tolerance
  • Dark phenolic color wafer for vintage look
  • Dished back dual supported shaft
  • Solid brass shaft and bushing with dual retention
  • C-Clip reinforced shaft
  • Lowest torque offered by CTS
  • Beveled edge split shaft for easy knob installation and alignment
  • Fine spline split shaft fits modern and vintage Gibson knobs
  • Vintage Original 1950's New Old Stock Sprague Bumblebee .022/200V 20% Paper in Oil tone capacitors
  • True varnished NOS glass fiber cambric insulation tubing sleeves for the cap legs (and switch ground) that is made in house here (60’s harnesses will use yellow rubberized cambric insulation).
index.php
index.php
ReWind James
ReWind Electric Pickups Gear & Instrument Services
Platinum Supporting Member
The caps are vintage but not NOS, and they are 400v, not 200v (400v being the vintage correct type).
Otherwise, I think that's accurate, though the photos don't load for me.
GLWS!
