Reverb tank upgrade recommendations? PRS HG70.
pillbug
I have this PRS head which I LOVE ... but the spring tank is very hissy/noisy when you turn it up past noon, and you have to turn it up past noon to get enough of the mix in there. So I am wondering what would be a good spring tank upgrade for this amp, that would have good presence, dwell, and tone, without all the extra noise?
rabidhamster
Reverb tanks are highly susceptible to interference. Could even just be deteriorated shielding on connecting wires.
As far as replacement tanks your choices are Accutronics and Mod, with Mod being easier to obtain these days. They’re both good, but I can’t help you with the correct tank. There were only 250 of your amp made, so be sure to save the old parts for future collector resale. If you pop that sucker open it’ll be some reverb tank that was for sale in the mid 80s, shouldn’t be too hard to replace. There will be a part number printed on it, you may need to unscrew it to get at it
jlee
The Korean made Accutronics tanks are notoriously delicate. I prefer the sound to MOD tanks, but be prepared to replace your Accutronics. The Accutronics aren’t as splashy. If you’re after Fender style splash and drip, the MOD would be a better choice.
northernguitarguy
SWeAT hOg
While I totally appreciate purity, might I suggest an awesome reverb pedal (of which there are a plethora for all budgets) in the loop? I was going to fix the Accutronics tank in my Peavey Bandit, but instead found pedals sounded better, gave more options, some were a cheaper 'fix' and all were more fun! :cool2:
YMMV
pillbug
YMMV
I play lots of different reverb pedals thru the front of the amp. Haven’t used the loop. I’ll try that!
northernguitarguy
SWeAT hOg
I found that even the most basic reverb pedal was as good or better. I had a Mooer ShimVerb in there, and while most of the Strymon effect it was trying to be SUCKED, the ‘spring’ setting was great (maybe not to a point of drenched effect, dunno exactly what you’re after). A used analog Tech 21 pedal in the loop was otherworldly.
pillbug
Thanks. I have a HOF that I’m gonna try.
like your new avatar btw.
northernguitarguy
SWeAT hOg
Perfect! I look forward to your impressions.
Thanks! (I guess? I'm only borrowing it). Always loved that album cover. However, I realized that much of my pentatonic wanking is fully (subconsciously?) inspired (lifted?) from Eddie Hazel's playing. As well, 'Maggot Brain' as a 'state of mind' seems apt for the times.
I hope to one day replace it with a pic of my aging ass on an axe trying to once again claim some local glory (and having a blast in the process).
pillbug
HOF in the FX loop sounds great! I also found my new favorite drive pedal, the Greer Southland. Had a touch of Slapback via the Supro delay (into front of amp, no particular reason other than laziness).
Was playing my Rock n Roll relics Heartbreaker. Had it cranked up as loud as I’ve ever played in the house, for an hour this morning, windows open and cloudy breeze coming in, it was Magic!
