Renkenstein
- Joined
- Jul 29, 2013
- Messages
- 183
- Reaction score
- 151
Prologue:
Good day, MLP patrons! I'm pleased to announce that I'm starting my first build thread.
After 6 months of lurking, drooling, and reading everything you guys have offered up on the forum, I finally feel comfortable enough to start my own build thread.
I hope I'm not cursing myself. I got a LOT of traction this weekend, and I thought I'd get started on the thread. There isn't a whole lot going on that's interesting per-se, but I thought I could gather info, ask opinions, and get some direction earlier in the game instead of waiting for it later.
My success in the shop has been limited due to rookie mistakes. I've started 2 necks and botched them both, but one is fixable, and the other can become a cigar box guitar or something. I did have a moment of success this summer when I built a nice cigar box guitar that was a gift for a friend on Father's Day. Due to these mistakes, I've decided to change gears and actually work off a known good set of plans instead of spinning my wheels trying to get my original designs to manifest themselves. Once I have success with this LP, then I will turn my attention to original builds.
Without further ado, HERE WE GO!!!
The LP I'm building is going to be based off the Tom Bartlett plans, but I have no interest in it being vintage accurate. All that nonsense with the angle of the control cavity and all that....going right out the window. Don't need it.
I'll be using a 5 piece mahogany body(I can only assume it's the African variety) because that's what I had on hand. I'll be using a maple top with subtle curl, so it's closer to a plain top than anything else. I'm planning on making a 3 piece laminated neck that will be quartersawn mahogany/maple/mahogany, and I want to use a curly maple fretboard. I've always thought LPs look BOSS with a maple fretboard, and I've always wanted one.
For pickups, I'll either be enlisting a friend of mine who builds Scarlett Amps, or I will be using my tried and true Duncan JB/Jazz combo. I'm leaning towards the Scarlett ones though because Paul(Scarlett Amps...check em out!) is insisting that I use his pickups for a build. Not gonna argue...the guy is an electronics and tone mastermind.
Bartlett Plans:
This is what I'm basing my first LP build on...the Tom Bartlett '59 plans. Close to 6' wide. Crazy. Order 2 from Tom. Copies at Kinko's cost almost as much as the plans themselves, and they have to use a roller scan on images that large, which can translate into distortion over the length of the plan. Give Tom your money, not Kinko's.
This image has been resized. Click this bar to view the full image. The original image is sized 3504x2336.
Made a template for a template for other templates:
First template of 1/4" hardboard. I glue-sticked a copy of the Bartlett plan to make a quick template to transfer to MDF.
This image has been resized. Click this bar to view the full image. The original image is sized 2048x1536.
Master Template:
After transferring from the first template to the MDF, I sanded to the outer edge of the pencil line with a disk sander for the outer curves and used rasps on the inner curves like the cutaway and her waist. I then took the template down to the inner part of the original pencil line with a card scraper. I slowly sneaked up on the inside of the line, making sure to maintain a perfectly perpendicular edge, and fluid curves throughout every transition. This will be my master template for all flush-trim routing.
This image has been resized. Click this bar to view the full image. The original image is sized 960x720.
Hunk o' Maple!
This was an off-cut of curly maple I got a decent deal on. Perfect thickness for bookmatching. A little plain, and light on the figure, but I think it'll be pretty enough. I can get 2 tops out of this piece.
X-Cut
I like using hand saws whenever possible. I especially like cross cutting with a handsaw because my table saw is sketchy at the best of times. I also have challenged myself to cut perfectly by hand like the good old boys. I'm still working on it, but getting better every time.
Top #1
This is the piece I'll be using for my first LP top, but first it has to be bookmatched. It's a 7" tall cut and my bandsaw only cuts 6" high. What to do?!? I guess I'll have to use that sketchy table saw....
Sketchy Table Saw
So here's the target of my ire. This table saw has given me nothing but problems. I found out there's over 1mm of deflection from the front and back of the fence towards the middle, and I can never get a cut that's a perfect 90 degrees to the table top. This won't do.
Wood fence?
That's right. Screw that chintzy metal fence...we're gonna fix it with a good old piece of maple. I planed it perfectly flat and made sure I had a perpendicular edge. I used my Stanley #5 for this job.
Bolt holes
I used the existing holes in the fence and marked the spacing off on the maple. I drilled the holes and countersunk them with a spade bit to fit these bolts I took off a bed frame long ago.
Bolting on the maple fence
I bolted on the maple using lock-nuts, making sure to leave it just barely snug in the middle to secure, but not flex it up against the fence.
This image has been resized. Click this bar to view the full image. The original image is sized 2336x3504.
Checking for 90 degrees
Once bolted on, I checked for 90 degrees, and I think I nailed it.
Bartlett Plans:
Master Template:
Hunk o' Maple!
X-Cut
Top #1
Sketchy Table Saw
Wood fence?
Bolt holes
