eddie_bowers
- Joined
- Oct 5, 2007
- Messages
- 906
- Reaction score
- 220
I literally reinvented it because what I came up with I later found is called the Grease Bucket circuit from Fender
But anyway, this is the most usable tone control I have had up to now.
One of the problems with a standard tone control is that as you bring down the treble the cutoff frequency also shifts to the bass side obliterating your mids. You can use a lower value cap, but that doesn't do much in the 0 to 5 range of the tone control and the cutoff is a little high until you go below 5.
The solution is to use the other side of the tone pot (the unused post) to slowly add in another cap in series (twice the value of the other one works best) as you turn down the tone control. This decreses the total capcitance as the tone is turned down keeping the cutoff frequency above the midrange (for the most part). I'm using a .01 and adding in a .022 as I turn down.
This sounds great!
In addition to that i'm using two different types of caps. I have some Jupiter caps that sound really smooth but loose any crispness/harmonics below 5 on the control. My vitamin Qs sound best to me in that 5 to 0 range. So i'm using them both. It really is the best of both worlds.
I encourage anyone who has some spare caps lying around to try this.
I will post a diagram when I get a chance, but here is how it's wired. Looking at the bottom of the pot with the lugs pointing down, the left lug being lug 1 and the right one being lug 3.
Lug 1 connects to the signal (pre or post volume)
Lug 2 connects to a .022 Vitamin Q cap to Lug1
Lug 3 connects to a .01 Jupiter to ground (or pot case)
Thats it.
-Eddie
This sounds great!
Thats it.
-Eddie
