- Joined
- Mar 19, 2010
- Messages
- 50,825
- Reaction score
- 172,973
Try it out. If you can make headway with the 1000, use that. It's less work to remove scratches in the end, which can be frustrating.
It doesn't remove orange peel as quickly as 600 will, but 600 leaves scratches that are hard to get out. Especially if you are polishing by hand.
Through experience, I've found it much easier to get that scratchless sheen by starting out sanding with finer grits. It's more elbow-grease at first, but much less labor in the long run to get the fine scratches out.
Be sure to clean your paper frequently with naptha and a rough rag, lacquer builds up quickly and you don't want any wayward "bits n' boogers" hiding under or on the paper adding scratches as you work. Clean off the residue from the body surface frequently too.
