question about wiring ...
Buncek
hey !
i have a SD TB-6 humbucker and i have one push/pull pot and few SPDT switches ... on push pull i will do series/paralel wiring ... and i'd like to have a split coil too ... can it be done with this combination ?? cuzz i cant get DPDT(on/on/on) switch...
Buncek
Wiring Diagram
well then take off the push/pulls from the last one and add this "in between" the pots and the pickups.
if you are unsure of the color code on the second diagram, refer to this
Wiring Diagram
hmm i'll try to do it by this second schematic ... but i'm not sure if it will work cuzz it says something about two pickups and i have just one ...
hellraiser_666
The two pickup thing is for phase reversal, So if you are just doing normal phase, it will work fine
Buncek
what if i take this wiring and then solder one more wire in where is white wire soldered and take it to the switch and then from other end of switch go for ground ... would that work ??
180gROC
hellraiser_666
honestly man, i have no idea if that would work
AngryHatter
Obviously, the only requirement of the pickup is that it is four conductor.
