I like them.For those of you guys that do wiring mods - is this type of push pull pot any good? I remember when the CTS push pulls seemed to be much more heavy duty.
Almost tele-esque?For a HSS strat the coil cut is most obvious. I would do that. But on another pot I like the option of when you pull the pot, it adds the neck single coil while the other side of the switch cuts a coil from the bridge humbucker simultaneously...so when you switch to the humbucker on your 5 way with this pot pulled up you get single coil at the bridge and neck pup together.
yesAlmost tele-esque?
