SpinWheelz
- Joined
- Oct 3, 2008
- Messages
- 1,883
- Reaction score
- 95
I'm trying to use a push-pull pot as my bridge tone control in order to activate in- and out-of-phase sounds, and I'm having some trouble with the pot in "pull" mode.
I've wired it up as follows. As you can see, it's '50s wiring, with a push-pull as tone control.
Trouble is, when I select with the bridge pickup or both pickups, and pull the knob, the pickup goes dead. It works perfectly well when pushed in. I expect no change in sound when it's just the bridge pickup selected, but I get nothing at all when the knob is in pull mode. When both pickups are selected, they're perfectly in phase in push mode, but dead silent in pull mode.
I've tried re-soldering all the contact points on the pot. I've tried re-doing the criss-cross part, I've tried re-soldering all the grounding. But I'm still coming up empty.
Since the pot works perfectly well in "push" mode, could it be only specific lugs that are in need of some better soldering? If so, which ones? Would appreciate any help you can offer.
Cheers!
Cheers!
