KissTone
- Joined
- Dec 26, 2009
- Messages
- 251
- Reaction score
- 89
I posted my experiences over at The Gear Page, but I thought I'd better share them here as well . . .
When do I learn to stop tinkering and leave things well enough alone?
I've never been a big fan of the Gotoh snot green tulip button tuners--though they function well enough, I didn't like the play in the post and I hate the greenish color.
So enter the TonePros Klusons----solid and stable (plus a much better button color) on the recent LP Traditional I had. So lets put a set on my R6.
Well, yes, it can be done, but not without drilling/reaming.
First, TonePros posts are smaller diameter, so you must use their press-fit bushings so that the post doesn't lean when tuned up . . . bushings which require a slightly larger hole (23/64") than Gotoh (22/64") . . .
Second, TonePros have a collar at the base of the post which also requires a 23/64" hole so that the tuner body can sit flat against the back of the peghead. In other words, might as well drill/ream the entire way through . . .
Third, the mounting screw holes on the TonePros baseplate are smaller diameter than the stock Gotoh holes meaning that you either drill out the baseplate holes so you can reuse the Gotoh screws or just use the provided TonePros screws . . .
Fourth, the provided TonePros screws are a slightly smaller diameter than the Gotoh---though thankfully they still bit into the wood enough to hold . . . but stripping could occur easily if you aren't careful . . .
Fifth, the screw holes are just off enough in the baseplate from the Gotoh holes that the TonePros screws go in at a slight angle. Again, it still works, but just.
Besides that, Mrs. Lincoln, how'd you like the play?
Despite these issues, these still are nice tuners---but NOT direct replacements. Proceed at your own risk.
