Profiling the back of the neck...
voices
I had an idea and wondered if anyone has tried or does it this way:
Use a large roundover on each side of the back of the neck to get a symmetrical profile.
What say you?
nuance97
A 1” radius will give you a really good “Gibsonish” profile. It has definitely been done. The headstock angle makes it tricky, and has prevented me from trying it, but it is very common on Fender style necks
voices
I was thinking of maybe stopping short of the headstock and up by the end of the neck ...then doing the rest by hand.
voices
also, if you routed fingerboard side down, you wouldn't have to worry about the headstock angle.
pshupe
The facet method is pretty good but you would need some rasps. Cut the profile to the exact dimension for the thickness you want. Then mark a pencil line on the center, and the facets. Then rasp away the major amounts and feather with rasps and sand paper. Make sure to never hit your center line in the middle so the profile depth always stays.
Obvioulsy the dimensions are different for different profiles. You could just do half way and then use a profile gauge or template to finish.
Cheers Peter.
voices
Cheers Peter.
That is the way I've been doing it but my results aren't what I want. my necks seem to be all over the place and not uniform. Remember I told you about that 70's V i have with the perfect neck? Its almost a half circle at the fist fret. Thats what I'm looking to do.
voices
There are always these... but you'll need to either trim away some material ahead of routing, or you'll need a very heavy duty router in a table or a shaper. An overhead pin router could potentially work as well... certainly handheld routing would be out of the question.
this was the one i was lookin at. im wanting to do almost a half circle profile and adjust from there. I'm not sure if I'm explaining it right.
nuance97
Yes that is the only way it’s possible on a Gibson style neck, but if you’re like me (no pin router) you have to build a floating jig which is easy enough, however the size of the router base itself makes getting close to the headstock problematic. It may not be as difficult as I imagine though...I’ve never gotten past the “thinking about it” phase.
nuance97
This is a good video on it...with a pin router
voices
couldn't I just do it on a router table using the bearing as my guide?
nuance97
Not any way I can conceive of...a Fender style neck absolutely, but not a neck with an angled headstock. Unless I’m missing something
cmjohnson
I actually have used a cutter like that for profiling a neck but it's only good for rough profiling. It'll save you some time but it's not going to keep you from putting a lot of hand work into making a neck shape you'll really like.
I'll use that cutter again for future necks. It is a good labor saver, but is not a labor eliminator by any stretch of the imagination.
I use mine in my milling machine. I have to, because its shank diameter is one inch and that won't fit in any router I ever even heard of.
danigalapago
Wow! I bought this 1” router bit last night for this purpose.
you’ll need a pin router in order to profile a neck with an angled headstock.
pavel
Not owning a pin router, I've had pretty good results in the past with the Bill Scheltema neck contouring jig. It looks like there are a lot of different variations/improvements out there including this:
which looks pretty fancy. (Disclaimer: didn't try this version myself).
I have gone back to shaping necks with a nice rasp because to me it's one of the most enjoyable parts of building.
cmjohnson
Most of my neck shaping has always been done with a 6x48" belt sander. After that, random orbital sander and a progression of grits. I do a little work up in the throat and the heel with my oscillating spindle sander.
Using carve templates, a straightedge, and a set of dial calipers I can nail my desired neck profiles rather well.
voices
like this? but with a bigger bit
voices
@ Gibson, we had a huge belt sander to do the back profiles. It was the length of the neck so it would trim it all in one operation. I don't have a belt sander (yet) but eventually want to do it in a similar way. For now, I'm just investigating the possibility of using the router with the bit I mentioned.
pshupe
That's called a dead head sander and it is probably the quickest way to shape a neck, not to mention vintage correct.
If you incorporate stops for the different profiles and necks. It would be very very useful.
Cheers Peter.
nuance97
Sure, but how can you do that from a router table? The angle of your headstock makes that impossible does it not? It won’t sit flat like a Fender style neck. You’d have to mount the router overhead
