BeerGolfGuitars
- Joined
- May 13, 2019
- Messages
- 93
- Reaction score
- 217
I posted this a couple days ago in a the pickup sub forum and am hoping I have a little more luck here. Sorry in advance if you read this twice, but here goes...
I have a quick wiring question I’m hoping you all could weigh in on. I have a set of Probuckers from an Epi LP Custom Pro with quick connects that I’d like to swap into my Epi Standard Gold Top, also with connectors.
Understanding that I’d be losing the coil splitting function since the Standard doesn’t have push/pull pots, are there any other things I need to consider? Or is it as simple as plug and play?
I’m hoping to learn if swapping just the pickups with the existing connector harnesses will work, or if further modifications are necessary to get the Probuckers going in the Epi Standard.
Thanks for your help!
