egrassel
- Joined
- Sep 27, 2010
- Messages
- 587
- Reaction score
- 428
Looking to sell my Swart Space Tone Reverb Tweed in Dark Tweed - This sound is unique, yet familiar. Tweed sound in its blood - with a reverb that is out of its world. 5 watts, through a 12 inch speaker sounds huge. I have the opportunity to pick up a vintage tweed, so I gotta move this.
1000 now 900 shipped pp/gift -
The point to point, hand-wired STR-Tweed has three driver/preamp tubes comprised of two 12AX7s and one 12DW7 with a parallel Reverb stage utilizing the 12DW7 & 12AX7, providing the circuit with virtually zero insertion loss. And like all Swart amplifiers, the STR-Tweed is tube rectified by the JJ 5AR4/GZ34 for the best AC filtering bringing great compression and tone, avoiding the typical solid state harshness that seems to ride along with solid state rectification. Try a vintage 5Y3 for a bit more SAG and less voltage on the power tubes.
STR-Tweed Specifications
- 5W CLASS A ~ JUST INSANELY BIG TONE BREAKUP!
- Single-Ended Output - Zero Negative Feedback
- 100% Tube Circuit - GZ34 or 5Y3 Valve Rectifier
- Big Swart Tube Reverb - Foot Switchable
- Hot and Clean mode Switch
- Powered by choice of 6V6 or 6L6 (shod w/6V6)!
- JJ 12AX7(2) - JJ 12DW7 - EH 6V6GT - JJ GZ34 Rectifier
- Point to Point Hand Wired Circuit
- Cathode Biased (no need to bias)
- Carbon Comp Resistors ~ Mallory Caps
- Cloth Hook-Up Wire
- Hi/Lo Input for High & Low powered Pickups
- Heaters referenced to ground
- Standby Switch for tube warm-up, extending tube life
- All Swart Amplifiers employ Star Grounding
- 4/8 ohm 1/4" Out - Drive other Speaker/Cabinet
- Switchcraft 1/4 inch inputs and output
- CTS Potentiometers
- Custom High Quality USA Built Swart Spec Iron
- Speaker: 12" Mojotone BV-30H ~ 8 ohm
- Finger-Jointed, solid Pine Cab w/ Lacquer Tweed Cover
- Vintage Jewel Lamp ~ Circuit Fuse Protected
- 17" W x 10 3/4" D X 16 3/4" H (w/feet) ~ 29.5
