FLICKOFLASH
- Joined
- Mar 17, 2007
- Messages
- 24,847
- Reaction score
- 8,615
Pre-Wired Les Paul Wiring Harness w/ Luxe Bumblebee Capacitors
Makes upgrading your Les Paul or similar very easy with this high quality, drop in replacement wiring harness. All parts are brand new and carefully pre-wired.
They use CTS 500K audio taper potentiometers, Luxe Paper-in-Oil reproduction Bumblebee Capacitors (.022 @ 400V) and vintage cloth wire.
Everything is professionally wired for a neat appearance and optimum tonal operation.
All kits are wired using the "50's Vintage Style" wiring scheme. A detailed schematic is also included for your convenience.
Choose Short or Long Shaft pots depending on your guitar type. We highly recommend that you check your existing pot shaft length to ensure you pick the correct kit.
No hype! Just great tone!
