Pin router/Help!
crowguitars
Such a tool would like to make suggestions and look forward to your help!
Everyone thank you in advance
Ganorin
Sorry, I'm sure its a language thing, but I really don't know what you need/what your problem is...
Can you rephrase your question?
cheers
Alex (not native english speaking...)
freaktone
Not really sure what your asking here... are you asking how to build a homemade one? There are some great jigs for this around and a great site for extruded aluminum to make on like the Stew Mac binding jig is 80/20® Inc. - The Industrial Erector Set® and you can get cheap stuff from their ebay auctions.
Ole'Lefty
Sorry-English is my only real language. But I would need to be sure of your location before I could have a sense of your particular options. I use a compact dinosaur of a pin router-not exciting but for what we do, I believe it is ideal. EDIT: The middle photo shows it as it ended up in final configuration. The lower router is a 3.25 HP. and I use pins shaped like straight router bits as the lower guide pin. The table is Jessem and when being used as a conventional router table, it has a Jessem fence too.
My "trick" for aligning top router with "guide pin" below---I have small pieces of tubing with inside diameter that match pin and bit. I slide the tubing over the lower and can adjust table so that the cutting bit nicely dops into the little tube-lock it down, remove tube and ready to rock. Dust control is lousy but we try.
crowguitars
Excuse me, if I composed badly.
I would like to build pin router and I would ask the ideas
Ole'Lefty
So, then, are you considering a non-powered plunge-something like my old Shopsmith? Power ones, [google "shopfox"] use electricity and pneumatic control. Industrial ones are dual powered too and weigh nearly 4kg.
crowguitars
Thank you, this really good. Would be very expensive only to bring in onto Hungary. I would need some cheaper solution
Ganorin
How much would you be willing to pay?...there are a lot of good used machine on the market....I had a selfmade one and upgraded to a commercial (old, used) one, the difference is huge...
schoeftinger
Well, I got one to give away... :)
50 years old, functional, very useful...
... but too large for my workshop after all!
It comes with a lot of tools too...
Maybe I should put it in the members classified section... :hmm:
cheers,
-Tom
Edit: Alex, you beat me to it... always a bit faster ;)
