- Joined
- Apr 7, 2012
- Messages
- 14,296
- Reaction score
- 34,708
A little background... I have an '81 LPC. I'm the original owner; I purchased it brand new. Other than the recent refretting, it is 100% stock. You can see it and read about it here in this thread.
After some serious consideration, I'm going to replace the stock Shaw pups, with a set of Duncan Seth Lover's (SH-55, 4-conductor wiring). Some folks love the Shaw's... I do not. I'm not looking for any input on that decision.
Wiring appears to be straightforward. Looking at the Duncan wiring chart on this link, it's a combination of using the "Standard Wiring for 4-Conductor Humbuckers" and the "Coil Splitting" option below it.
So, I opened up the control cavity to have a look. You can see it in the picture below. Here's what I found:
Bridge Volume Pot: 137943 70-034
Neck Volume Pot: 137943 70-034
Bridge Tone Pot: 1378045 71-079
Neck Tone Pot: 137804? 71-079
Bridge and Neck Caps: MP 203Z 50V
From what I can find, looking here, the 70-034's are 300K linear taper (long shaft?) and the 71-079's shown here are 100K audio taper (long shaft?).
The Cap's appear to be just plain ol' ceramic/mylar 0.022uF... nothing special about them.
Here's where I would appreciate your thoughts, comments & suggestions...
1. Replacement Pot's - must be push/pull for the coil splitting.
a. Long shaft is required for my year, yes?
b. What R value for Volume Pot?
c. What R value for Tone Pot?
d. Linear or audio taper, or a combination?
If anyone has specific part numbers, from specific sources - that would be great.
2. Caps - not so worried about PIO or other esoteric composition.
a. What C value for bridge?
b. What C value for neck?
3. General comments/thoughts about putting all this together.
Thanks for reading and thanks in advance for any and all responses!!!
