P-90: Great tone, nice bite and cuts through in the lower mids. It has single coil characteristics, like the spank in the mids, but still has a LP sound, with the growl and big bottom end. Noisy asthough, nothing you can do about it
Tung, Hmm Ever run thru a Seymour Duncan Convertible amp? every strat I have played thru mine , The 60 Cycle was reduced to near barely noticed levels Since Seymour is such a fan of single coil tones as much or more than Humbuckers, might be worth a try if you can find one Though I am not much of an effects user, I have found going thru a Zoom 505 with ther ZNR turned on helps cut it back too
