Pick Up Height
Misch
I also had bridge PU much higher than neck PU to get pretty equal volume between both. This way bridge also got more "power" compare to neck. Also tended to lower bridge PU on high strings a bit to compensate for equal volume on lower and higher strings. Today i don't follow any meassurment because enough practice with hearing tells me what to do. This things were a lot simpler without internet :)
Misch
Beside guitar consider amp as a part of it. Like house needs a roof guitar needs an amp. Roofs can be very different, some leak water, some make house very hot, other are ok, etc. :)
Anyway, if you are into rock tube amps try Vox for brighter sound, Fenders can also be bright but often used for other genres. 18W models tend to offer surprisingly wide pallete of sound because they can be driven a lot easier than 50-100W rarely anyone can open in typical apartment or even neighborhood. I'm very much into audio electronics where experiences showed this things, like relation of guitar to amp...
PeHow3
Yea I just adjust them till I like the response. I don't worry about measurements much.
