PA Design - Live Sound
sidepartings26
Hello everyone
Not sure what sub-forum to stick this is in so backstage it is.
I have to design a PA system. I am a student asking for advice. If you consider me 'lazy' or what not then sorry; I am in fact trying.
In simple terms the requirement is a modular system which will cover a single gig up to 6 kW; but which could also cover 4 simultaneous 1kW events if need be (mostly rock/heavy and acoustic gigs).
The large system:
- Needs to have both FOH and separate stage monitoring consoles [so will need a splitter box or separate splitter unit for the monitor console?]
- Needs to facilitate a 6-way monitor mix. 2 side fills are also needed
The small systems:
- At least two monitor mixes from FOH with a minimum of one provision for effects
All systems:
- Necessary sound processors [dynamics. Effects] for all FOH and monitoring requirements
- A good range of microphones and stands, able to handle various instruments/reinforcement
- Cables and accessories
Obviously it makes sense to be able to re-use as much equipment from the big system for the smaller systems (e.g. the monitoring desk as a FOH desk for a smaller system).
The total ‘budget’ is £75,000.
I can work out microphones; cables; accessories and probably the four desks too. I am struggling with amplifier and speaker choices (I understand impedance matching/basic principles) i.e. how many speakers an amplifier can be expected to power and how many speakers to go for. Initially I was thinking about a line array which could be broken down but I have ruled this out now because of dispersion angles?
I would appreciate any help/guidance you can spare me!
Thanks
lp_junkie
Here in the US I use Carvin gear for PA needs, they have scalable setups that will cover everything that you are needing to do.
Not sure if they ship internationally but that would be a great place to get ideas from.
Carvin.com is their website.
