Are you having a problem with the pedal and need to fix it?
Yeah, I took the insides out to install in a custom board that I'm building. I extended the wiring to the footswitch and to start with it was working fine. Tried it a day or 2 later and it has suddenly stopped working. It bypasses ok but when the pedal is on, there is no sound. The led lights but that is all. What do you think has happened?
Brilliant Glynne, thanks a million mate.
I however have noticed that when I link the bottom of the c5 cap to the top of the c4 one, it works but I have no control over the gain vr. Do you think the C5 cap has had it??
Paul
If your pedal matches the schematic found HERE when you connect those capacitors you're bypassing the gain stage. That's why there's no control. Which leads me to believe you may have a bad connection on that first stage of the IC.
IC1a you mean? You are probably right as it intermitidally worked a couple of days ago when I picked the board up. What do you suggest I do?
