rjwilson37
- Joined
- Dec 30, 2010
- Messages
- 6,662
- Reaction score
- 4,537
When I received my TH30, not to long after I tried using the 4 Cable Method for hooking up my Firehawk FX Multi-Effects Unit so that I could have control about what is in front of the Pre-Amp or behind it and such. Well... not matter what I did with the Software/or Unit to config it for what is said to work with the amp, I could not use my amps gain channel, the amp just stayed clean. I used it using the 3 Cable Method which worked and I had to put everything behind the loop and it worked, but I still did not have the flexibility I was looking for.
Well... I just picked up the Helix HX Effects last week to replace my Firehawk FX and just I just connected it using the 3 Cable method to start of with. It has a lot better effects and is working great, but when I get home today, I am going to try the 4 Cable Method and see if I can get it setup and have it work properly with my TH30. I love the tone I get from my TH30 and just wanted effects which is why I got the Helix HX Effects.
