freefrog
- Joined
- May 21, 2011
- Messages
- 1,662
- Reaction score
- 1,046
OK, thx. Before your answer, I had already modelized the circuit with a 8k / 4H humbucker (P.A.F. specs) + a 6k / 2.5H Strat PU (L Series specs) and I'll show below what it gives.
Before the pic, an explanation: by putting the humbucker in series with a cap then a phase switch between pickups, you've created a way to put them "half OOP".
Below is a 5spice sim of what happens when the volume pot of the bridge unit is progressively lowered...
-while the two pickups are enabled in parallel and out of phase (left screen),
-while the bridge pickup with its series cap is enabled alone (right screen).
Red curves = volume pots full up.
Black lines = bridge volume pot lowered from 9/10 to 1/10.
Vertical lines = approximative locations of the lowest and highest fundamental notes produced by a normal 6 strings electric guitar.
The "half OOP" relationship makes the volume control of the bridge PU almost inefficient and promotes the mids as soon as this volume control is lowered a bit.
The horizontal green line shows that in this case, mids are at the same level than with the bridge pickup enabled alone... and even that your "half OOP" mid position will be louder in the mids than the bridge transducer alone as soon as its volume control is no more @ 10/10.
FWIW (an hastily done 5spice sim; but physical reality should be close to it).
