RTH,
Actually, I was throwing out to Coppercrimp Rob,
But yup, if I need to, I still do it and it does work.
Hope all is well with you and yours.
One Detroit boy to another,
Willy
I was serious about leaving the strings on to re-shim. However, this all started on my bass, and at $30 a pop for a set of 5, you learn to conserve. Eventually, I realized that I dont even like new bass strings. I wont change them until they are rusty. If I wipe them down with a little WD-40 every week (if I'm playing alot), they will last forever. And the best part about a bass is that the top of the tuners are open slotted. Metal fatigue be damned!
The way I see it, if Dan Erlewine has been promoting the use of Naptha (a toxic hydrocarbon and highly combustible) to clean guitars and fingerboards for several decades, I'm not afraid of a little WD-40.
I also read somewhere that the flat spots on the strings from fretting won't line up when you restring so it's bad for your frets.
Then it would stand to reason that new strings are bad for your frets too, because the windings haven't flattened yet.![]()
Maybe I said that wrong. If the flat spots that were on the strings from the original install get twisted, then some frets get "fresh" wind contact and some get flat spots or partial flat spots so the contact isn't even.
At any rate, $3/set not worth arguing over, just throw new strings on. I buy them this way now, it's much faster when you have a bunch of guits hanging around:
Two things I don't reuse... one is guitar strings, the other, toilet paper.
