- Joined
- Jul 7, 2011
- Messages
- 14,970
- Reaction score
- 21,150
My new Axe FX III came yesterday.
Spent hours playing through it, until my fingers hurt.
It is a phenomenal piece of kit.
If I hadn't already had an Axe FX II XL+, it would be a jaw dropping experience.
I'll do an in depth review, after more time.
For now I'll try to answer the question, If I have an Axe II, should I get the Axe III?
There is no simple answer. It depends.
I was A/Bing my Axe FX II XL+ running the Ares 2.0 Firmware (The Axe III models ported to Axe II). Does the III sound better? Feel Better? Yes. But it is not a major difference, I can hear it, but it is very subtle. I can't even find the words to describe it, except it is slightly more complex, 3D.
So, if you re running simple (and by that I mean, simple by Axe standards) presets, some in front FX, an amp. or even 2 stacked, post fx, simple to moderate signal routing, then you are likely going to be just as happy with an Axe II, particularly an XL or XL+.
Using an XL II, particularly an XL+ for a lot of people, on stage, or in the studio, you will be happy for years and years. I always thought mine was the equal, tonally, playability, feel, etc, of the tube amps I had, as well as the Kemper I had. It still is. It will be for years to come.
Granted, you would be stuck with the almost 300 amp models, the effects it had/has, as the Ares 2.0 is, as of now, the last firmware upgrade. Then again, the Ares 1.0 was supposed to be the last, when it was released. There are a LOT of Axe IIs out there. So who knows. Seems like the new platforms get primary attention right now.
But even with that the case, no more update, you can still tweak at such a deep level on everything, you can, for all intent and purpose, create new amp models, fx models, stomps etc. from exisiting models. When you can cange tube types cap values, etc. etc. you can make models sound a lot different.
So why get the Axe FX III?, Well, what the Axe III brings to the table is MORE.
It has more cpu horsepower, memory, amp models, presets, IRs, preset and IR storage capacity, i/o ports and signal path routing. When I go more in depth, I'll delve into some of that.
The Axe III has more and faster processors. They also split duty. So, for instance, unlike the Axe II, where the 2 processsors ran EVERYTHING, the III splits processing mong the processors. 2 are dedicated to the modelling, another runs the graphics, another handles the USB and user interface duties.
So, if you are a 'power user', or want more than one guitarist using the same unit on stage (possible with the III), or love to tweak, tone chase, experiment, need about as complex of signal routing as you can conceive OR must stack 4 amp models together (or route them crazyly), then yep, the III is worth the purchase. I fall into this category.
Things I really like (as compared to Axe II, and so far as there is a lot left to explore)
Shorter unit. Axe 2 needed a deeper, bigger rack case. Axe III fits in the less deep cases.
Front controls and Display. Yea, Display is more modern, crisper, color et al. But, I find it a LOT easier to actually use the front panel and not need Axe Edit. For instance Its very simple (as in a second or two) to bring up the amp controls one usually uses, gain, volume, eq, and use the quick control knobs that are right under the corresponding control on the display, and adjust. It is real easy to just pull up and find a preset from the front panel. All things I would never do on the Axe IIs front panel.
K, I do like the colors and look of the new front. The changing color Axe FX III looks cool.
Headphone interface is now the best I've heard on anything, as far as sounding like what I hear externally on Monitors or FRFR 2x12. VERY little difference (at east with my headphones), which means not having presets tweaked substantially different for each.
There are some new things in the models, a preset levelling tool and others I'll go to in depth at another time.
What I don't like
That it exists. Since it came out a little more than a year after I got my Axe FX II XL+, it gave me GAS
It's 3 rack units high. Granted it is why it's shorter in depth (see above), and is needed for the new screen.
All in all
I am pleased. If not for GAS for this, I would have been super happy staying with the Axe FX II XL+. But, I don't regret getting the III. AND, the planets did align to make it possible.
Kept the screen protect film on for awhile
With the Axe II XL+ when I was A/Bing and making sure new Axe was gtg
Now, as King of the rack
What I don't like
All in all
