My Precious!
As it's pretty smooth, I really can't see that ring as the culprit here, unless you're performing some vicious hammer ons.
My wedding band is similar, but with deep Hawaiian carving on it, and even though I can sense ring contact with the binding, I haven't seen any damage or wear.
... then again, I don't use a slide.
The edges of the ring are somewhat sharp, even after all these years.
Also, there is a raised design on the other side that works it's way around my finger while I wear it.
When I play slide, I hold my fingers out, extended to cover the strings, so when reaching for notes on the 5th & 6th strings, I have to reach across the fret board. Which makes my ring touch the binging on the high "E" side.
I've never had this problem with nitro before, but it is the only reason that makes sense.
That puts my wedding ring right in the effected area.
Live and learn....
He said that the problem appeared to be that some residue from fret work was still on the binding prior to the final clear coat application.
Yep, that's why buying new is almost pointless. The warranty for life will only do you any good if you have a video of you playing while the guitar bursts into splinters. Then they might cover it.
Deal with a local luthier and you should be fine. I wouldln't want to ship an expensive instrument for something like that anyhow.
Very big congrats, SW!
Halfway to satisfaction, I'd say.
No comments or explanations about the parts? I guess no complaints from you.
Cheers!![]()
