NG:Vashenko LP One Piece Top AND Great Photos
Russ2
Valera Vaschenko is an old world master luthier. Valery builds and assembles each guitar and provides awesome build photos as it progresses. This is basically a 59LP but a few changes such as the ebony fret board.
Guitar Body - Mahogany 1 piece
Guitar top - Single piece eastern Maple Top
Guitar neck - Mahogany 1 piece
Fretboard - Ebony
Fretwire - Jescar FW10051
Neck binding - Royalite
Body binding - Royalite
Headstock Veneer - Holly veneer
Headstock inlay VV
Tuners - Kluson single line
Nut - Mastadon Bone
Bridge - Kluson ABR1
Tailpiece Kluson Stop tailpiece
Jack - Swithcraft
Jack plate - Cream
Neck Inlay - Cellulose nitrate trapeziod
Neck Side Markers - Faux tortise shell
Pickup rings - M69 style
Truss rod cover - 59 Gibson
Volume Potentiometers - CTS 500k
Tone Potentiometers - CTS 500K
Toggle switch - Switchcraft toggle switch, cream tip
Toggle switch - poker chip Gibson
Capacitors - Russian mil spec PIO .022mf
Knobs - 59 speed knobs
Electronics plates - Matching mahogany
Pickguard - Larry to determine
Pickups Vaschenko wind - Larry to detail
Neck Radius - 12 degrees
Frets - 22
Neck Joint - 59 Gibson long tenon
Neck Carve - Medium C
Cabling - pickups Historic steel jacket
Cabling - switch Historic steel jacket
Cabling - jack Historic steel jacket
Wiring - Style 50's style
Truss rod - Single rod
Truss rod bolt and headstock - assembly Vaschenko 2-way
Headstock - style Gibson 59
Neck width @ Nut 1.695"
Neck width @ Heel 2-1/4"
Neck depth @ first fret 22.5mm (.887")
Neck depth @ 11th fret 24.7mm (0.972")
Scale Length 24.75" (Les Paul)
Finish/Body Top Lemon Burst
Finsh/Body Back and Sides Gibson Faded Red
Finish /Neck Nitrocellulose Lacquer
Finish /Headstock front Nitrocellulose Lacquer
Finish/Headstock Back Nitrocellulose Lacquer
String Guage and action height Gauge 10 - 46 low action
Serial Number Larry to determine
buckwild
KILLER BUILD! Valery is really a master luthier, his wood working is so cool to watch and behold. One thing I’d say though, I don’t like his finishes, the color was a bit odd on my guitar, too much yellow toner used etc. also the finish was really thick on the binding, which I did not care for. Maybe he’s improved since I ordered mine. I sent it to historic makeovers and got a good thin finish out on it...truth be told it was one of the better sounding Les Pauls I’ve owned. The fact that he takes photos of whole process is wonderful.
Olds442
amazing 1 piece top on that beauty.
Russ2
I am a Vaschenkoholic, this will be my 6th guitar. Valery started to wind his own pickups for clients upon request and they are gorgeous and sound as good as they look. Here is the set on my last build, I went with the Maple and Ebony combo in a Zebra pattern, various wood bobbins are available:
