ivan H
- Joined
- Apr 19, 2014
- Messages
- 129
- Reaction score
- 168
I've always liked the '68 spec JMP50 amps, lusted after would probably be more correct. I've built clones of, the last with period correct iskra resistors, C296 mustards etc, but stayed on the lookout for the real deal. Finally got one in reasonably good condition, serial No. S/11225, not "pristine", but still has all original Iskra resistors, C296 mustards (Chicklet 0.68uf cathode bypass caps), RS silver mica's, factory applied lacquer/dye still on 90% of solder joints, original Drake iron (PT 1202-118, OT 784-139, Filter Choke 352-114).
Finding an amp of this type & vintage that has not been molested in some way isn't common. This one has at some time had some kind of out/in loop added, now removed & put back to stock. Also, some damn fool has scarred the V2a cathode bypass (Chicklet) cap with the soldering iron. I do have this cap in both the C296 mustard & Chicklet types that I could replace it with, however as it's still functional I'll leave as is so as not to disturb the lacquer/dye on the solder joints. The Bulgin AC socket has been replaced with an IEC type, but I've ordered the correct 3 prong Bulgin socket & plug to put back in. It has been re-capped at some time. Previous owner had it re-valved a while back with NOS Mullard CV4004 12AX7's & a matched duet of NOS 1965 Rohen Telefunken "00" getters winged plate EL34's. Here's pics
I have NOS "spares" for this if ever needed that include a complete set of Philips Mullard C296 mustard caps & Philips Chicklet 0.68uf 250V cathode bypass caps & some Iskra resistors. NOS valves that I have include a matched duet of matching date code (B2J3, Blackburn plant, 1962, October, 3rd week) Blackburn Mullard "00" getters xf2 EL34's, (the EL34 type it would originally been fitted with), a few duets of the 70's era Blackburn Mullard single halo getter xf2 EL34's & a good few Blackburn Mullard 163 series 12AX7's. I'm working away a the moment so will have to wait for the weekend to give it a clean-up & once over & play through. Cheers
Edit:
I'll most likely be changing out the bias supply electrolytic capacitors as part of the clean-up/once over. Cheers
Edit:
