sillennium
- Joined
- Nov 10, 2010
- Messages
- 639
- Reaction score
- 391
$1600 plus shipping to your location, to be calculated when contacted.
In a nutshell, the Marshall all-valve, 4-channel JVM410H 100-Watt tube head is the most versatile Marshall amplifier ever made.
Each of its 4 channels--Clean, Crunch, OD1 & OD2--are not only completely independent of each other, they all boast 3 Modes, all 12 of which are footswitchable and feature their own unique gain structure. It makes the JVM 4-channel effectively 12 Marshalls in one!
Add to this an ingenious footswitch (UK patent pending) and the fact all the amp's switching (channel/modes, Reverb, Master Volume selection, FX loop) can be done via MIDI and you're looking at an incredibly flexible amp! The 6-way footswitch boasts 7 LEDs and memory, plus it connects to the amp via a regular guitar cable.
From the cleanest clean to the filthiest distortion ever found in a Marshall and all points in-between, the JVM410H all-valve amp head will give you whatever tone you need right when you need it.
Features
100-Watt valve head
Valve complement: 4 x ECC83 (12AX7s) in preamp, 1 x ECC83 and 4 x EL34s in power amp
4 independent, footswitchable channels--Clean, Crunch, OD1 & OD2
Each channel boasts 3 footswitchable modes -- Green, Orange & Red
Studio quality, footswitchable digital reverb with level controls for all 4 channels.
2 footswitchable master volumes
Two FX loops -- Series/Parallel & Parallel
Series/Parallel FX loop is footswitchable
Emulated line out
6-way, 7-LED footswitch with memory capabilities (UK patent pending)
All switching can be done via MIDI
Made in England
The footswitch has a minor scratch on it, this is how I got it so cheap and now I selling it to you even cheaper! CALL or TEXT: (Eight 1 Eight) 2 6 9 1026
