New CTS Push Pull pots exclusively from Mojotone!
EXCLUSIVE!!!! CTS DPDT Push-Pull Potentiometers by Mojotone!
Available in 500k and 250k
The best push-pull potentiometer ever made, by CTS exclusively for Mojotone! These aren't your standard off the shelf CTS pots either. We had them custom made to our specification to have the smoothest taper possible and the tightest tolerance available. These are ruggedly built to last just like all of our premium quality CTS potentiometers.
Custom taper for a smoother volume or tone control
7% tolerance. Tightest tolerance available!
Solid brass split shaft and bushing (3/8'' diameter x 3/8'' length)
Freddy G
Thank you. Now I will finally pull the trigger on building a 21 tone Jimmy Page harness.
need a long one...
We'll see how the short ones sell first. If they do really well, I will consider adding long shaft. For our regular pots, the short shaft ones sell 10 to 1 to the long shaft and we have order thousands at a time.
alsoty
Hope can get the long soon...
Thank you for replying.
alsoty
Hello mojotone,
I just order 2 of them,
I'm afraid that I can't use them on my LPJ, but I still order 2 haha!!
There is one question,
How to wire them?
These tiny hole that I draw?
Thank you.
kboman
Any chance of these being availiable from others at some point you think? You guys are all the way over there in foreign land across the ocean :(
Hello mojotone,
How to wire them?
Thank you.
Notice how the solder terminals on the board are labeled to match the 6 pins soldered to the board from the DPDT switch. So C1 solder terminal connects to the C1 pin on the switch, 1 to 1, 2 to 2, and so on. Just look at the 6 pins (3x3) when comparing to any DPDT switch diagram and solder to the matching terminal. It's very simple I promise.
Soon I hope. We just received them a few days ago and it usually takes a couple months or so before our dealers stock new items.
alsoty
Hi,
I found the material is hard to solder when I want to make ground.
I think that's Aluminium?
InsertUsernameHere
Hi,
Looks like they are coated, sand it down a bit with some fine grit sandpaper, and it should be a breeze to solder.
Bump....
Thanks to the high demand for the 250k and 500k short shaft CTS push pull pots, I am adding the 500k long shaft to our inventory. They are on order from CTS and will be available soon!
