New 1963 Les Paul Junior day!
fernieite
Well, I finally did it. I've been wanting one of these for quite sometime, since playing a few in vintage stores over the years. So, yesterday I bought a very cool 1963 Les Paul Junior! (SG)
I was able to sell a bit of gear this past week...
Anyway, this one has Centralab pots dated the 21st week of 1963, (1346321) and a serial number of 1207XX. It's also a birth year guitar for me. The neck shape is very nice. I just measured the following - 1st fret .80" / 3rd .84 / 5th .88 / 7th .92 / 9th .96 / 12th 1.01 / 15th 1.04 / 17th 1.06. I like the feel - it's just right. And yes, it sounds killer!
The cherry finish has faded quite a bit on the top, and has tons of finish checking all over. I've just cleaned it with Virtuoso cleaner and will do it again to get the final grunge off. The board looks quite nice and dark, but needs a cleaning too.
I've just emailed Dan (Danelectro) at Mojoaxe to get a replacement pickguard and bridge. The original bridge was in the non-original generic case, and some sort of butt ugly compensated bridge was installed. (I have a generation 1 Protector case, so I'll sell off the generic case) The original pickguard has shrunken at the holes and cracked. The nut maybe original, but it has been shimmed a bit higher for the slightly higher replacement bridge, I suspect.
The original tuners are gone, and it has a set of Gibson deluxe (made in Germany) white tipped pegs. They look like Klusons on the back and Grovers (with the nut and washer) on the front. I may want to get a set of original tuners or repros, if it's possible to put it back to stock. Conversion bushings maybe?
Is the Gibson logo under the finish on these? If so, I'd like to clean the headstock. I'm pretty sure the silk screened "les Paul junior" in on top of the finish, right? - So I'll avoid that area...
Sorry, I don't have any pictures yet. But, they'll come later...
bossaddict
@david.beason on IG
Congrats! Looking forward to seeing it once you've got it ready.
I believe the logo is under the nitro and the model silk screen is on top as you said.
Conversion bushings will work, but I haven't found a set that have the grommet-style that a Junior would have had.
StudioFan
Congrats !
I know how you feel as I picked up a 65 SG Junior a little while ago .
They just ring forever and are great to play .
I just got a pickguard from Dan at Mojoaxe and his compensated bridge .
He customized the template for mine to cover a neck pickup route , widened it 3mm in one area .
Great guy to deal with !
He also sells aged screws and pointers for these which I added.
Don’t mind my bridge ground or the bridge angle , not quite finished with that yet !
I bet yours has less holes too :thumb:
CerebralGasket
Congrats!
An SG with a P-90 (or two) is my favorite kind of SG.
I am convinced that these Juniors have better sustain than the Specials due to the lack of a neck pickup which may create pull on the strings from the magnetic field.
When I got my '58 RI Les Paul Junior DC, I noticed the increased sustain right away compared to my SG Classics with two P-90's. I got my Junior second hand and it came with a Mojoaxe Wraparound bridge and the intonation is perfect that guitar.
The headstock logo is silkscreen under the clear coat on Juniors. Specials from this era had the headstock logo as inlay.
fernieite
Thanks guys! I'm totally stoked - I love this guitar!
I've got a very cool set of original vintage Kluson single lined "3 on a plate" tuners coming, and an aged pickguard and compensated "lightning bolt" bridge from Dan (Mojoaxe)
I'll also be getting a few vintage bits and screws to bring this beauty back to stock.
OBX351
Congrats! These are magical guitars. I have a '63 LP SG Jr. It's one of the best sounding guitars I've ever played. All day woman tone, light, and insane sustain....to quote Spinal Tap:
"the sustain, just listen to it"
"I am not hearing it"
"you would though if you were playing"
fernieite
I got a nice surprise email from Gibson last week. I thought they had stopped giving out the shipping ledger info. Maybe it's just a matter of timing...
Anyway, here's my guitar's shipping date:
Hi,
In the Gibson Shipping Ledger Archives the serial number 1207XX shows a Les Paul (SG) Junior model shipped from the Kalamazoo, MI factory on 6/25/1963.
Thanks, and I hope this helps!
Interesting. My pots are dated the 21st week of 1963 - so May 20-26, and the guitar was shipped out about a month later - on Tuesday June the 25th.
I guess they got a fresh order of 500k pots from Centralab towards the end of May and soon after installed a set in my guitar, before setting it up and shipping it out towards the end of June. I was born around the middle of March that year, so this guitar and I are very close to the same age. :cool:
