Need some help with LP Identification
lovehifi
Guy just email me about a possible trade for a Strat I have. He said its a 2014 Gibson Custom Shop Lemonburst. In the pics it looks VOS and had what appears to me a Anniversary emblem on the fretboard. Just have not seen one like this. Any thoughts or help would be great.
lovehifi
Guy says it a It is a 2014 Gibson Les Paul Classic 120th Anniversary and he had the Custom Shop do some upgrades.
CerebralGasket
This one does not fool me.
I had a 2014 LP Traditional Honey Burst in the past with very similar streaked grain pattern on the top.
Looks like a 2014 LP Traditional Honey Burst with the following mods:
1. Aged nickel pup covers, bridge, tailpiece.
2. PUP selector switch cover plate changed out.
3. PUP selector switch tip changed to amber.
4. TRC plate changed from Traditional to blank.
They even flipped the bridge and saddles on that Nashville so that the screws are facing the pickups like an ABR-1.
Look at the "MODEL" font on the headstock.
That is typical of a regular production USA model.
Tuners are also incorrect for Custom Shop.
Should be press fit bushings.
See "MODEL" on headstock below for comparison...
Gibson's Custom Shop doesn't do mods to customers' guitars.
He means he bought a Custom Shop switchplate on eBay or Reverb and put it on his Gibson USA LP Classic.
(Many people who buy CS Historics take those switchplates off and replace them with vintage-correct plastic. Some keep them with rest of the case candy, some sell them.)
The Custom Shop has made versions of the LP Classic, but those have a CS decal on the back of the headstock, thin fretboard binding, and ABR bridges.
Assuming it's actually a Classic as he said and not a Trad or some other Gibson USA model...
I looked up the specs of the 2014 120th Anniversary LP Classic. Should have chrome hardware -- looks like he replaced everything with nickel.
Stock pickups were open coils. He may just have added nickel covers, or may have replaced the pickups entirely.
Factory was 3 speed knobs, with a mini-toggle where the bridge tone knob usually is. That was a smaller hole -- he had to enlarge it to add the normal tone knob.
The switch was for the built-in 15dB boost/preamp -- he may have removed that.
The volume knobs were push/pull for coil splitting.
Grover tuners were replaced with Kluson-style.
None of those mods are bad. A lot of players like me would actually prefer what he's done to it.
Especially because the mods don't add any value (possibly reduce value). Cheaper than buying a stock used one and then buying new parts for it.
Bottom line, it's a modded LP Classic worth no more than any other LP Classic (probably less).
lovehifi
Here is what he said. "It is a 2014 Gibson Les Paul Classic 120th Anniversary. In 2014 I had Gibson Custom Shop “upgrade” it. They installed 50’s style wiring harness, tonepros locking bridge & tailpiece, ‘57 classic paf’s, amber knobs, amber switch tip, blank truss rod cover, did a full set up, and Custom shop historic series switch plate cover. It has the 120th Anniversary inlay at the 12th fret. So, this one is pretty much a one off, upgraded to look and play like an R8 model. Dead mint with original case, and plays great. "
mudface
Boo Bee
Call Gibson Custom Shop ,.... they will tell you they don’t do mods to regular production Gibson’s.
You’re being fooled.
Cjsinla
There’s no way the Custom Shop would add that switch plate anyway, even if they did work on it.
