Need bridge recommendation for Melody Maker
Uncle Vinnie
Proud Boomer
Friend of mine has a '63 Melody Maker with a Leo Quan Badass bridge, which it seems the bridge saddles unfortunately raise the strings way too high above the fretboard.
What would be a good replacement for the original top wrap bridge?
I think Mojoaxe do different versions of compensated wrap tailpieces.
Uncle Vinnie
Proud Boomer
Compensated? How does that differ from original?
Well, vintage lightning bolt bridges are compensated. The break point resembles the staggered saddles on TOM bridges.
efstop
The dickens you say!
Gibson replaced the angled, uncompensated bridge in or before 1963 with the lightning bar. It should be fairly easy to find a replacement, as Gibson has used that bridge on many models, past and present. The current design works with a plain G, the original had the G saddle ridge rearward for a wound G.
efstop
Any multipiece bridge will not couple the strings to the body as well as a wraptail, IMO. Simple to set up. Two bolts for height, two grub screws for intonation.
pshupe
Buy it from Dan at the source. Might be a little cheaper and I'm sure Dan gets a little more $$$$. LINK
Cheers Peter.
