Need advice in the bridge of my SG
  • Thread starter Phylodog
Phylodog
I picked this up recently in a trade but had shoulder replacement around the same time so I haven't been able to really go over it. I was looking it over today and noticed that the A string appears to sit below the E and D strings. What little bit I've played it I didn't notice anything in the way it plays but I'm only a year back into playing so I definitely don't have the most educated hands. I've upgraded a few guitars with Faber parts but was kind of hoping to keep this one original.
Any advice on what to do here, if anything?
narsenyev
From the first picture looks like the low E isn’t in its saddle, making it higher than the A
Can you try “clicking” it into place?
Subterfuge
invest in an understring radius gauge ...
Phylodog
Well sonofa........
Thanks for pointing out the obvious. Someone please delete this thread before the whole world finds out I'm a moron lol.
I'm blaming the pain meds :)
Roxy13
Just have a good laugh and enjoy your new SG :)
cmjohnson
D and G strings look like they're at different heights. They should ideally be the same or VERY close to it. Since you probably DO want the low E to be a little higher than the high E, but usually the difference is just about 1/64th of an inch. From D to G that's hardly even noticeable. It's like 3 thousandths of an inch.
E and E should be the lowest two. D and G should be the highest two. A and B should be in the middle.
Using a radius gauge, the saddles should have notches in them that are cut so that the strings are right on a comfortable radius, anything between a 12 and 16 inch radius to be reasonably precise about it.
Each saddle should have enough of a notch in it that strings don't pop out under heavy strumming near the bridge.
