True, but I was finally able to measure the level of the rod with the straight edgeYou've posted about this before with the truss rod being maxxed out, You need to get that taken care of.
That gap does not look bad considering that you have zero tension on the truss rod.You're correct on all counts. I sent an email to tech support at StewMac and they said this can happen over time, a slight warp in the neck.
Run the nut back down until it contacts, and give it 1/4 turn, let the neck relax for 15 or 20 minutes, then check it again. If there's still a gap, give it another 1/4 turn.
That is not excessive relief for having a deactivated truss rod.
That is pretty close to what you want to see with the string tension on the neck, so you really don't need much. There is nothing wrong with your guitar and your truss rod is not maxed out.
From the start, the postings on this guitar have been confusing because of the unclear use of terms like "maxed out" and "relief"My mistake.. fom the way I read it the nut was bottomed out and there was still too much relief.
Yes! I thought I was the only one who worked on their guitars in the kitchen! But actually I prefer the kitchen island, it’s the perfect height and it’s square as opposed to round.BTW.. I am a kitchen table hack so if someone else says DON'T DO THAT....don't do that.
