Schrodinger's Cat
- Joined
- Apr 18, 2010
- Messages
- 159
- Reaction score
- 25
Hey guys, I've been having volume problems when I switch to neck pickup position on my Epi LP for a while and wondering if any of you guys can give me any ideas.
The main thing that happens is if I'm playing with my switch on the bridge position and my amp volume set to 3, and then I switch over to the neck position, I get half as much sound and I have to turn up my amp volume to 6 in order to get the same volume output.
Also, what's weird is the neck pickup volume knob doesn't get any sound when I turn it all the way to 10, but if I turn the knob down a bit to 9 or 8, it starts getting sound.
I've tried adjusting the action and pickup heights already but they don't help. The bridge pickup seems to be working fine though. I also opened up the covers to the pots and the pup selector to check for anything abnormal. As far as I could tell, the pup selector seems to be ok. When I checked the wiring on the backs of the pots, there was a red wire (I think volume wire? not sure...) running to the neck pot that had a few loose strands sticking out. I tried heating the solder and mashing the loose strands in. The loose strands are in now (I think ) but the volume problem is still there.
I'm wondering what I should consider next? Any thoughts or advice would be greatly appreciated. I feel like I'm playing with only half of my guitar at this point.
Here's a picture of the wiring at the back of my Epi LP if that helps at all. I searched the forum and it seemed like people who had a similar problem to mine just re-wired everything and got it to work, but I just wanted to run this by the forum and see if there is anything I'm missing.
