CreamTone
MLP Vendor
- Joined
- Nov 8, 2011
- Messages
- 699
- Reaction score
- 631
the beauty of a locking bridge and TP is that they don't fall off the guitar when you do a string change.![]()
I agree with you there!
The Bridge is a Faber Nashville Spaced ABR-1 with Stewmac Nickel posts.
Nice. Was any drilling required to convert from the nashville bridge?
None at all. The threads from the StewMac posts were a perfect fit, and the Faber ABRN is specifically designed to be a direct replacement for a Nashville bridge. I could put it back stock in a few minutes if I ever needed to.
That looks like a million bucks! The plastics did a number on it. So those are plain old Dimarzio rings, huh...
Thanks for the kind comment!
Yep, those are plain old DiMarzio 5-dollar rings. Really good match for the Allparts guard. I like how tall the DiMarzios are. What I did was put a piece of 600-grit sandpaper on the top of the guitar and rubbed the rings back and forth over it until they had a slight arch on the bottom to follow the contour of the body. Took a little time but it's worth it.
Damn! I keep coming back to check out that top.
That would have to equal some of the nicer R9's I've seen.
Hang onto that puppy. She's a beauty![]()
Adambomb, for the Faber ABRN bridge I got I changed the posts on mine with the NWSKit so I could use the locks. The posts are just a tad higher that existing ones that let you put the lock nut on them to lock the ABRN down.
NSWKIT Steel Bridge Studs - CV Guitars
I dunno why he top wraps howeverIn my case I also upgraded the TP studs for the Faber ToneLock. They come with spacers they you can use if putting it flush with the body is too great of an angle and hit the back of the ABR before it hits the saddle so if you don't have to top wrap. I haven't tried the top wrap but I don't think I'd like felling the strings over the top of the TP.
Reading their FAQ and watching the video helped me
CV Guitars
Faber Locking Bridge Installation - YouTube
Question: Why did you change your original bridge posts? Could you have took the tail piece all the way down without the top wrap or would that be too much string breakage? I'm interested in the same bridge upgrade but I was wondering if it was necessary to change bridge posts.
That turned out nice, it looks great. I may have to get one of those guards and DiMarzio rings as the pinkish hue of the plastics is starting t bug me![]()
