MyLesPaul462
- Joined
- Jul 25, 2021
- Messages
- 220
- Reaction score
- 332
Hey I got one for you guys. I got the ole 57' Tweed Champ out to try out a new pedal yesterday, and I started to hear a sound. The best way I could describe it was like when you have a rodent near by maybe in a crawl space/just behind the drywall. Turns out its coming from the amp. Sure enough, it sounds like a little critter is inside scratching at the vinyl speaker cover or something. First I was freaked out that something had happened to the speaker, or a cap is shorting or I got a messed up contact. But the tone itself still comes through strong and sounds solid. And this scratchy sound continues after I've turned it off and the circuit is not longer active.
Here's my theory: it's been cold and I think the pinewood frame of the amp is reacting to the heat of the amp when it's on and warping slighting cause things to crackle a little bit. After a while it settles and the sound stops.
Alright Amp tech's, what's your take? have you ever heard of something like this happening? If it's not that, then what is it?
