Each pre-wired harness includes the following:
(2) CTS 550K Premium Custom Audio Taper Potentiometers with 10% Tolerance for both volume positions. These are not your standard issue CTS pots. Although these are marketed and labeled as CTS 500K, they are actually spec'd at 550K to ensure that pots meter no lower than 500K. These pots have a very responsive sweep and are metered for optimal placement in the harness.
(2) MojoTone 500K Push/Pull Potentiometers for both tone positions. These high quality US Spec potentiometers have brass shafts and typically spec between 450-530K.
(2) New Old Stock Paper in Oil Capacitors.
Each harness is meticulously wired 50's style and properly grounded with vintage correct 20AWG bus wire.
This harness allows you to split coils on both humbucker pickups.
**4 Conductor Pickups Required**
Harness is tested prior to shipping to ensure proper operation.
Wiring Diagram Included.
Available with short or long shaft pots.
Prewired Premium LP Dual Coil Split Harness
