MOD Kits DIY Treble Boost "The Penetrator"
AmplifiedParts
MLP Sponsor
The Penetrator –Treble Boost Pedal Kit: New from MOD® Kits DIY
The Penetrator is a treble boost pedal kit with enough gain to cut straight through any mix. This pedal adds glistening harmonics that get loud enough to saturate your amp’s front end. Adjust the level knob to vary the output so there’s no mistaking when you kick this pedal in. Great for solos or when you need your guitar front and center.
MOD® Kits are designed to give novice and experienced musicians the opportunity to build their own amps and effects pedals. All kits come with easy-to-follow instructions and use point-to-point wiring. A pre-drilled enclosure and all necessary parts are included. All you need to provide are hand tools, a soldering iron and solder. The effect pedal operates on a 9V battery; for a longer lasting option, a 9-volt adapter can be purchased separately.
For a complete listing of kits available from MOD® Kits DIY visit: www.modkitsdiy.com
Freddy G
It's certainly reasonably priced! I think I'll order one....but I'd just like to comment that your video demo could have been a lot better. It would have been much more useful to hear the pedal on with the guitar player playing exactly the same riff as he played with it off.
