Fromtherock86
- Joined
- May 21, 2020
- Messages
- 19
- Reaction score
- 8
Hi all,
Newbie to the forum at least officially, so glad to have finally registered.
This is a bit of an odd one.
Years ago, after discovering the Japanese copies of Gibsons, like Burny, Greco, Ibanez, Aria et cetera,I set my sights on buying a Flying V. Gibsons were a bit pricey at the time so I found a used Cherrywood ‘import’ V for a good price in the UK, which is where I am based. Once I had the guitar at home there were some obvious changes to what would originally have been its spec and it was quite beaten up! The previous owner had made that quite clear though so I knew what I was buying. Firstly there was a Seymour Duncan JB in the bridge, not stock. They were mini Grover tuners, not stock. The most interesting thing was the Ibanez super 80s pick up in the neck position and I also noticed after some time that the Guitar’s legs were smaller than on an average Flying V.
Which is why now after nearly 10 years I am writing this post, took my time! I had previously posted something similar many years ago but couldn’t get much information back. I’ve scoured through catalogues, Internet searches and not found a similar looking V.I’m attaching pictures of what it originally looked like once I received it.
My mods:
Graphtech nut
Duesenberg tremolo
Painted it black
Changed vol and tone knobs
Below are photos and some specs that I can give which might help trace his guitar to its maker. Any help would be appreciated, I’m just curious. Thanks again.
Set neck construction
Neck width: about 5cm
Neck depth: about 2cm
Had a rectangular stop tail piece not Gibson like (now replaced with a Duesenberg tremolo)
Body is made of two parts, split line can be seen on the side of the body.
Pointed headstock / no truss rod cover (Recently added a smaller black one)
Scratchplate has a non pointy edge on the bottom left
Was originally Cherry Red
Ibanez Super 80’s Pickup in the neck, might’ve had a Super 70’s in the bridge at one point
My mods:
Graphtech nut
Duesenberg tremolo
Painted it black
