- Joined
- Sep 17, 2011
- Messages
- 20,310
- Reaction score
- 25,840
Basically an OM-28 with a cutaway, and a pickup
Martin Guitar OMC-28 (Cutaway) E (electric) LR (LR Baggs pickup/Microphone) Anthem System.
Beautiful Sitka Spruce top, Solid Indian rosewood back and sides, scalloped bracing. Nice guitar!!!
See Martin Spec sheet below.
CONSTRUCTION: Dovetail Neck Joint
- BODY SIZE: 000-14 Fret Cutaway
- TOP MATERIAL: Sitka Spruce
- TOP DETAIL: None
- ROSETTE: Multi-Stripe
- BRACING PATTERN: X Brace
- BRACE SHAPE: Scalloped
- BRACE MATERIAL: Sitka Spruce
- BRACE SIZE: 1/4″
- BACK MATERIAL: East Indian Rosewood
- BACK DETAIL: None
- BACK PURFLING/STRIP: Style 28
- SIDE MATERIAL: East Indian Rosewood
- BINDING: Antique White
- TOP INLAY MATERIAL: Bold Herringbone
- BACK INLAY MATERIAL: Multi-Stripe
- NECK MATERIAL: Select Hardwood
- NECK SHAPE: Modified Low Oval
- NECK TAPER: High Performance Taper
- PLEK: Yes
- NUT MATERIAL: Bone
- HEADSTOCK SHAPE: Solid with Square Taper and Diamond
- HEADPLATE MATERIAL: East Indian Rosewood
- HEADPLATE LOGO STYLE: Script Old Style Overlay
- HEELCAP: Antique White
- FINGERBOARD MATERIAL: Ebony
- SCALE LENGTH: 25.4″
- NECK JOINS BODY AT: 14th Fret
- NUMBER OF FRETS TOTAL: 20
- FINGERBOARD WIDTH AT NUT: 1-3/4”
- FINGERBOARD WIDTH AT 12TH FRET: 2-1/8″
- FINGERBOARD INLAY MATERIAL: Abalone
- FINGERBOARD INLAY STYLE: Diamonds and Squares Long Pattern
- FINGERBOARD BINDING MATERIAL: None
- SIDE DOTS: White
- BACK & SIDE FINISH: Gloss
- BACK AND SIDE COLOR: None
- FINISH TOP: Gloss
- TOP COLOR: Aging Toner
- FINISH NECK: Satin
- NECK COLOR: Dark Mahogany
- BRIDGE MATERIAL: Ebony
- BRIDGE STYLE: Modern Belly – Drop in Saddle
- BRIDGE STRING SPACING: 2-5/32″
- SADDLE: Compensated White Tusq
- SADDLE RADIUS: 16”
- TUNING MACHINES: Nickel Open Gear
- BRIDGE PIN MATERIAL: White Plastic
- BRIDGE PIN DOTS: Faux Tortoise
- PICKGUARD: Faux Tortoise
- PICKGAURD INLAY: None
- CASE: Martin 630 Thermoplastic
- ELECTRONICS: LR Baggs Anthem
The condition of this guitar is excellent, There is a finish seam crack that is detectable on the top. Its just the nitro settling, where the seam between the top halves is.
$2500 and Shipping in CONUS~ paypal please add the 3% fee
or I will accept the gift option if you are comfortable with it.
OHSC and Martin Documentation
