Martin OMC-28 E LR *Reduced*
Sct13
Martin OMC-28 ELR
Basically an OM-28 with a cutaway, and a pickup
Martin Guitar OMC-28 (Cutaway) E (electric) LR (LR Baggs pickup/Microphone) Anthem System.
Beautiful Sitka Spruce top, Solid Indian rosewood back and sides, scalloped bracing. Nice guitar!!!
See Martin Spec sheet below.
  • CONSTRUCTION: Dovetail Neck Joint
  • BODY SIZE: 000-14 Fret Cutaway
  • TOP MATERIAL: Sitka Spruce
  • TOP DETAIL: None
  • ROSETTE: Multi-Stripe
  • BRACING PATTERN: X Brace
  • BRACE SHAPE: Scalloped
  • BRACE MATERIAL: Sitka Spruce
  • BRACE SIZE: 1/4″
  • BACK MATERIAL: East Indian Rosewood
  • BACK DETAIL: None
  • BACK PURFLING/STRIP: Style 28
  • SIDE MATERIAL: East Indian Rosewood
  • BINDING: Antique White
  • TOP INLAY MATERIAL: Bold Herringbone
  • BACK INLAY MATERIAL: Multi-Stripe
  • NECK MATERIAL: Select Hardwood
  • NECK SHAPE: Modified Low Oval
  • NECK TAPER: High Performance Taper
  • PLEK: Yes
  • NUT MATERIAL: Bone
  • HEADSTOCK SHAPE: Solid with Square Taper and Diamond
  • HEADPLATE MATERIAL: East Indian Rosewood
  • HEADPLATE LOGO STYLE: Script Old Style Overlay
  • HEELCAP: Antique White
  • FINGERBOARD MATERIAL: Ebony
  • SCALE LENGTH: 25.4″
  • NECK JOINS BODY AT: 14th Fret
  • NUMBER OF FRETS TOTAL: 20
  • FINGERBOARD WIDTH AT NUT: 1-3/4”
  • FINGERBOARD WIDTH AT 12TH FRET: 2-1/8″
  • FINGERBOARD INLAY MATERIAL: Abalone
  • FINGERBOARD INLAY STYLE: Diamonds and Squares Long Pattern
  • FINGERBOARD BINDING MATERIAL: None
  • SIDE DOTS: White
  • BACK & SIDE FINISH: Gloss
  • BACK AND SIDE COLOR: None
  • FINISH TOP: Gloss
  • TOP COLOR: Aging Toner
  • FINISH NECK: Satin
  • NECK COLOR: Dark Mahogany
  • BRIDGE MATERIAL: Ebony
  • BRIDGE STYLE: Modern Belly – Drop in Saddle
  • BRIDGE STRING SPACING: 2-5/32″
  • SADDLE: Compensated White Tusq
  • SADDLE RADIUS: 16”
  • TUNING MACHINES: Nickel Open Gear
  • BRIDGE PIN MATERIAL: White Plastic
  • BRIDGE PIN DOTS: Faux Tortoise
  • PICKGUARD: Faux Tortoise
  • PICKGAURD INLAY: None
  • CASE: Martin 630 Thermoplastic
  • ELECTRONICS: LR Baggs Anthem
$2650 and Shipping in CONUS~ paypal please add the 3% fee
or I will accept the gift option if you are comfortable with it.
OHSC and Martin Documentation
