Marshall SL5 Clean Mode Won't Switch
jw3571
All of a sudden my Marshall SL5 won't switch from the distortion to the clean channel. Doesn't work on the foot switch or on the amp. Suggestions?
Marshall & Moonshine
Not too familiar with it, but I'd do the dummy checks from the manual, like making sure there's nothing going on with the settings, effects loop, some switch on the back or whatever, then call the shop you got it from for warranty work.
Tiboy
Will the amp switch if you remove the foot switch? I had that problem a while back. The footswitch was the culprit. Marshall replaced it under warranty and all has been well ever since.
jw3571
I'll try the foot switch removal and give it a try. Thanks.
