QuarterTone
- Joined
- Dec 24, 2012
- Messages
- 139
- Reaction score
- 132
Hi all,
I've been playing a Marshall DSL40C for over a year and just upgraded to a JVM210C which I bought used off of ebay. I mostly loved the DSL40C but wanted the more tones, better footswitch, dual EQ, and better onboard reverb of the JVM among other things. I'm mostly liking the JVM but I've got one problem with it and I plan on taking it to my local amp tech to get it fixed, but I wanted to run the problem by you folks first and make there is really an issue here or if I'm just doing something wrong!
The issue is I've got close to zero clean head room on the clean green channel. When I'm on clean green If I turn the gain up anywhere past 1 (yes ONE) I start getting plenty of break-up like I'm on a light overdrive channel. Moderate strumming will break it up quite a bit and anything other than very light picking will break it up too. Again, this is with the gain anywhere past 1 and in all positions of master volume from low to high.
So I assume that I'm right to think that this amp needs to go into the shop? I'm thinking bad tube or bias adjustment needed or something but I don't much about amp maintenance and would rather pay a tech to work on it.
