Marshall DSL40CR. Just perfect
NINFNM
After many years using Fender and ENGL amps almost exclusively, I feel I've finally found my perfect one.
Years ago I was dissapointed with a 4210 JCM 800 but now Marshall has done what I needed just right:
Marshall driven sound and good cleans, portable, louder than you will need while sounding perfect at whisper volumes.
Only thing is that there's a noticeable volume drop when changing from crunch to clean, so what I though was a useless feature, 2 masters, becomes a must. I have to set one master louder for clean tones, and the other one for the rest of settings, and problem solved.
Just in a minute I had the amp perfectly set. I never was so happy with my previous amps, always fighting against that dryness that cranking the mids didnt solve.
I neither think about swaping the speaker, it sounds warm but bitting from the beggining, and only can change for the better as it breaks in.
Higly recomended if you want versatility without compromising the Marshall tone. There's is a reason for all that hype around it.
BKS
Used to have one, really nice amps had the older version. I sold it going for heads and cabs wich is easier for me. ....and I love my little 2061x even more and my 1959 for looks :rofl:
And the rest of them:cool2:
Enjoy your beast:dude::dude:
Brek
I read the same on the Marshall forum, seems like they hit some magic sweet spot with that one.
THDNUT
Platinum Supporting Member
Nice amp!
What kind of a Les Paul is that? Is that honest wear? It looks like it.
It looks like it has a maple neck.
NINFNM
It's a 92 standard with a repainted neck in white, is not maple. Battered due to using it almost exclusively for 20 years
  • Like
Reactions: tzd
JohnnyN
Just another old geezer
Congratulations :)
Roxy13
I have the older version and I do really like it, but that master sure solves that problem of the changing volume. Mine changes from clean to crunch and then again when you go to the red channel and again when you go into the second mode on that channel. Great amp for playing at home, but that would be an issue gigging I think.
ErictheRed
I actually wish that they made this in a 40 Watt head, I might pick it up. They only have a 100 or 20 Watt version, not sure why.
  • Like
Reactions: fry
rjwilson37
Sweet, the crunch mode on the Classic Gain channel is awesome on that amp. Congrats!
scrumm21
I have the older model and after doing the C-19 mod, I split equal time between Red and Green channels
Love it
rjwilson37
Love it
Isn't the C-19 mod, just clipping one of the capacitors or something like that?
